alright, where to begin...
car's been driving fine for years now and then i let it sit for a few weeks, install an oil cooler, took it out for a spin, noticed i was only getting about 12.3v while driving. thought the alternator was going out so i took it to baxter and o'reilly to have it tested. one said bad, one said good. he tested it 5 times so i'm gonna go with the alternator is fine. re-installed it and noticed the alternator fuse was blown....but the car still ran. (i know, no idea how the hell that happened) . replaced the fuse, started, 13.8~14.2v yaaaay its fixed. next day driving down 405 and BOOM everything shuts down. pulled off and replaced the fuse on the side of the road, when i go to connect the ground (after positive) sparks galore! towed it home and diagnostics.
i've checked the ground from the battery to the chassis and block, nothing touching or rubbing. i've checked the wire that comes off the alternator, no breaks or rub-through. i know the culprit is in the fuse box now. i traced the lines and so far discovered the short is either through the RTR fuse, alternator junction, or dome light. the test light lights up the brightest when the dome fuse is inserted then dimmer for alternator fuse and barely lit for the rtr fuse. i've gone in the fuse box inside the driver side and pulled each connector thing out (the ones that weren't fused to the case) and the test light didn't turn off so my guess is that the short lies between the fuse box inside fuse box (or if i'm really unlucky, one of the ones i couldn't pull out). Inspecting under the fender and as much as i can see elsewhere nothings rubbing, rubbed through or otherwise.
Am i missing something here? or do i just have to rip out the whole body harness :'(
