when you remove the charcoal canister, should you just cap off the fitting or attach it somewhere else?and whats the easyest way to take the steel line off the afm bracket? cut or grind it off or what?
The little spring loaded door is there to ensure you use 'unleaded' fuel. The nozzle at the pump is smaller than on leaded fuel nozzles. Up until the mid '90's, you could still buy leaded regular in many states.mkIIIman089 said:Isn't there a second trap door in the filler neck that will almost defeat the purpose of venting the gas cap? I'm not sure of this but I remember reading it somewhere.
