Any tips from you guys that have replaced the cam seals in your 7M?
im gonna have to do my intake cam seal this weekend.
Undo the cam caps and the seal pops out even with the permatex Lankylanky189 said:um...might wanna remove those cam gears at some point....
What exactly is permatex #4 called?IJ. said:2a: Put a thin coat of permatex #4 around the outside of the new seal and some grease around the inner lip this will let it slide into place and when the permatex sets it will stop the seal leaking or moving if you get blowby from engine wear.
I know :icon_biggIJ. said:LOL well you asked what it's called !
It's a gasket cement/compound/goo!
