Changed spark plugs and cleaned out throttle body, now idling at 1k
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
I changed out my spark plugs last night and gave my throttle body a good cleaning as well since I had to take it out anyways. I sprayed the throttle body down with carb cleaner, and scrubbed down the dirt and grime with a wire brush. All is well, put everything back in. I just now drove it not too long ago, and now I'm idling at 1k, before it was about 600-750ish normally. Also, it takes more pressure on the throttle pedal to geta reaction. Maybe I need to just lube up the assembly on the throttle body?
-Matt
89Joe
POTATOES!!!!!!!!!!!!!!!!!
Jul 22, 2005
300
Missouri
You probably just need to adjust the Throttle linkage a bit. That or the TPS just needs some turning.
johnathan1
Supra =
Aug 19, 2005
5,056
Did you seperate the TPS from the throttle body, or did you just disconnect the connector to it?
And it sounds like you probably messed up the throttle plate resting angle when you cleaned it...just adjust the idle screw until you get it to idle @ TSRM spec. which is 700RPM.
Also check for possible vacuum leaks.
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
I did take off the TPS, then put it back on after cleaning. I'll mess around with the throttle plate.
-Matt
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
like a voltmeter/ammeter/ohmmeter. standard radioshack fare.
stupid thing, but is the A/C on? when mine's on itll be idling around 1200rpm, when off itll rest around 700
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Gotcha, I have one of those. And this is with the A/C off.
-Matt
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Damn it, can't figure this out. Take the car out to make sure it's ok, and it goes back to idling at 1500 RPM. I try to adjust the TPS, barely does anything. I even tried adjusting the idle screw on the AFM, still nothing. This is really frustrating me.
-Matt
Clip
Oct 16, 2005
2,738
9
Virginia
weird. what about disconnecting the battery for a while to let everything reset itself, or would this do anything?
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
I unplugged the EFI fuse for abit, and nothing changed. Maybe since the TPS is electric it needs to reset itself?
-Matt
Clip
Oct 16, 2005
2,738
9
Virginia
could be, i haven't had to screw with the TPS yet. if you dont have access to the TSRM, just lemme know. ive got a full set sitting here beside me begging to be used.
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
I checked the TSRM, but maybe I'm retarded, and can't find the TPS faq?
-Matt
Clip
Oct 16, 2005
2,738
9
Virginia
youve tested it like the page fi-100 (engine manual) says? i'm not sure what it could be if you've set it like this states.
