Chamfer...ing?
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
I was reading my haynes manual about installing new pistons and it said I needed to chamfer the block. What the hell is chamfer and how do I do it? Is there a tool to make it easier?
It's putting a 45 degree cut on the top lip of the bore.
You can use a handheld deburring knife or a curved whetstone.
Not at all with the deburring tool!
See the blade at the top?
It can rotate as you pull it around the bore and will give you a nice radiused edge instead of 2 sharp edges like a chamfer tool will!
