Never seen anyone do either........
Ceramic is normally used as a heat barrier,
and dry film, like what is used on pistons wears quite quickly, and the result would be detrimental to bearing clearances.
I have seen hard chromed bearing journals.
it is much harder than the base material, and will stand up to a spun bearing.
Since it can only be ground with a diamond stone,
if it gets bearing material stuck to it, you can remove it with emery cloth, and never effect the journal diameter.
But it has to be done by someone specializing in cranks because there is a post treatment required to remove hydrogen embrittlement that comes from the plating process.
Not to mention the correct grinding equipment to bring the journals back down to size.
A quick google seach brought up severay places that do it.
Like these people:
http://www.ecgrinding.com/About_us.html
