cc's
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
I'm rockin the N/A and i have complete exhaust, intake, plugs, wires but I want more... I have the turbo fuel injectors:naughty: , can i install them to my "ge" to get more fuel? I'm sure i will have to mess with the ECU, but how do i go about this? :1zhelp:
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
How about using all turbo electronics and lexus afm with 550s on the NA. It would be like running a turbo without a turbo. When you get bored of the NA, just slap on a turbo. :bigthumb:
NA afm is a flapper valve. If you open it up some, you will need to make the flapper bigger to cover up the bigger hole. Too much work for such little gain.
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Ohhhh. The NA AFM is a flapper valve. That explains the size and difference from the Turbo one.....
I agree with tubbie. Not tubbie should tell you how much for all his turbo electronics!
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
That is a lot more money and work... Good idea though, but i have the turbo injectors just lying arround, i wanted to put them to good use! How much would it run to get all the turbo electronics?
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Fuzz420 said:
Drop the afm all together and go maft-pro.As for more air to go with the turbo injectors you have, look into a wet-nitrous system, tune it with the maftpro.You can have your cake and it eat too, if you have a mhg already that is ;)
I will never shoot nitrous through my supra!!! I dont want to get all hard core on this engine because i will be 1JZ sometime within next year... But what is Maft-pro? < i know a dumb question... I hear about it all the time but what is it?:aigo:
Fuzz420
Are U Here 2 take My Baby
http://www.maftpro.com/
And if your planing on going 1jz within the next year i would just sell the turbo injectors and put the money towards the 1jz
Fuzz420
87soup said:
And if your planing on going 1jz within the next year i would just sell the turbo injectors and put the money towards the 1jz[/QUOTE
oh.... I dont think i would get much for the injectors!
somethings better than nothing, another mans trash is another mans treasure. Take pics, make a forsale thread, and somebody will jump on them like stinch on underwear.:naughty:
tubbie
Apr 4, 2005
821
Hoschton, GA
harness ~ $125
ECU ~ $85
HAC sensor ~ $15
CPS ~ $45
Coil packs ~ $45
Ignitor ~ $45
Lexus AFM ~ $125
Total ~ $485
These are average prices, if you look around you can probably get everything for a bit cheaper then those. Yes it is a lot, but you figure with this setup, you will be able to run it to just about whatever power your heart desires.
Best thing is to not get the Lexus AFM, go MAP ECU, MAFT Pro, Greddy EMU, or good old HKS VPC.
Also, the advantage of this is you buy it over time. You won't have to have all the money up front..... Just my .06 cents.. :bigthumb:
If your going 1JZ... Don't waste anymore money on the 7M. Post the injectors on eBay, they sell all the time for around $40 -$50.
