cast vs tubular
rwd
60
quebec
what are you think about cast manifold like this
is it possible that give better response and toque due to higher backpressure and the shorter lenght of runner
dslocal
340
slo
I would tend to think not as a cast manifold is rougher inside and also isn't going to have as equal runner length.
Also backpressure isn't a good thing on a turbocharged car, I would think that the i.d of the manifold and the angle the exhaust exited the cylinder would make the biggest change if you were to build one.
Besides a tubular manifold looks way better.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
cast manifold will help out in the spooling department, but tubular is going to give you better overall power in the end
apexi287
401
Knoxville, TN
You want good scavenging effects on the exhaust side and with a turbo car minimal to no back pressure. A equal length twin scroll tubular manifold will out perform a crappy cast any day.
rwd
60
quebec
apexi287: do you have gt4088r?
what a/r are you using?
do you have any torque before 4000rpm
i have one but .95 a/r and 1jz,and i dont have torque until 4700-5000rpm
i'm tinking do swap to 2jz or 1.5jz and change to .85 a/r for low end torque
apexi287
401
Knoxville, TN
Yes I do with an .85 a/r spools very quick with great street manners. I build torque consistently up to 4k and past, a graph shows my torque at 300 ft/lbs right at 4k. Also consider the fact i don't hit full boost until about 3.5k.
rwd
60
quebec
you only have 10 pound of boost , and you have 300ft/lbs at 4000rpm!!!! :aigo:
i touch 300ft/lbs at 4700rpm but at 20psi
can you post your dyno sheet
apexi287
401
Knoxville, TN
Dyno sheet is in my thread, single/stinger take a look if you'd like there's a lot in there.
dejacky
175
"taxus"
+1 I agree :naughty:.
rwd
60
quebec
where can i buy 2jzgte tubular headers, i looked ebay , suprastore , mvp , titanmotorsport , driftmotion ,horsepowerfreak . No one have
- divided t4
- cheap $$
- wastegate runner can fit in rhd mk3 body
