carbon fiber drive shaft
5l_eater
I LIVE FOR THIS SHIT !
Jan 17, 2007
258
Maryland
titanmotorsports sells a carbonfiber drive shaft for r154 gearbox was wondering if anybody has this product?
also will it fit a 1jzgte?
figgie
Twin Cities, Minnesot-ah
Keros;1000550 said:
What advantages does it hold, if it's the same weight as the Al 1pc?
quite simple.
if it breaks, it become a giant broom sweeper. No damage to the underside or anything else as it is just carbon fiber just spinning around. Meaning new CF DS and you are good to go.
Same can not be said of Al DS.
Weight reduction is actually low on the list of why the switch over to CF DS.
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
Thanks Figgie.
You'll be happy to know that between your post and mine, some thought figured it out... then i read your post ;)
jdub
Feb 10, 2006
10,730
Valley of the Sun
I believe Duane ops tested this one ;)
(could be wrong though)
figgie
nope you are correct
though his gave the ghost not because of power but because of mfg defect (I think there was a crack or something to that effect).
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
logan;1000786 said:
Doesn't suprarich make one for a better price ?
suprarich = Titan dealer
You are not wrong.
I wouldn't say breaking it does zero damage - looking at the drive shaft tunnel, you can certainly see where it happened. I don't think it does *significant* damage.
eman2289
Noob..but not incompetent
Feb 23, 2007
618
Jersey
Where is it on their website??
Edit: Nevermind, I should have looked around more. Found it.
5l_eater
Jan 17, 2007
258
Maryland
i was simply wondring if any body had one with a 7m or 1jzand if they had problems with install and howm uch HP arethey running on it and whats the max it can with stand
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Duane is running one on his 7M, so if you are planning on pushing it over 819rwhp you might run into problems.
Duane's latest mods :D
