Since I've gotten my car running again, it's been giving me issues with not wanting to start. I'll turn the key and the relay will click, pump will prime, and lights dim but it doesn't crank. I was thinking it was relay realted b/c whenever it first started doing it, if you pushed the relay in or just moved it around the car would start the next try. But was wondering if it could also be the starter contacts, basically wanting to find out if I should check the same things I'd check on a M series motor. Also can I use 2J contacts?
Any help appreciated...
~Bryan
~Bryan
