my car was running fine the other day. i got on the highway and decided to go fast on the on ramp. it hit 4th and the car started losing power and smoking REALLY bad. oil was burning somehere. i barely got it back home. it was puttering and barely stayed alive. so i thought maybe it was the head gasket. so as i was starting to replace it i noticed after i took the exhaust manifold off number 4 cyl exhaust port had oil in it, the others were dry. so i was like. uh huh...there's my problem! but i eventually got the head off and the head gasket looked fine. a couple of things on it were questionable, but number 4 cyl looked just like the others, no major damage. so i put a new gasket on and set the timing and filled up with water and checked oil. everything looked ready to go. so i started her up. it won't even start now. somwtimes it will catch and start idleing but i have to give it gas. but i have to press the pedal really fast cause too much will kill it. smoke is coming out of the engine again. but i know where it's coming from.
so i'm thinking the front main oil seal is gone, so i'm on my way to get a new one and all other gaskets i need to do it properly and i realize........maybe......the piston rings are fried on cyl 4. i'm losing compression, oil is getting into that cyl and burning, then coming out from where the main oil seal is. smoke is coming from that area.
soooo......now me and the mad scientist are gonna have to rip apart the block, and replace the piston rings i fried! cause i doubt the front main seal going bad would make my engine run, or excuse me, not run like that....anybody.
