***EDIT: nevermind found the problem was a vac hose after all had to actually grab the hoses not just look at them
ok, i just did my clutch and flywheel. before i did the clutch and flywheel the car was running fine. no problems what so ever.
now after the clutch and flywheel job, the car won't idle at all. I can't even get the revs up past 3000. when i adjust the my low point on my afc, it can idle fine for a few seconds then loops fast slow fast slow.
I have checked codes and i don't have any.
I have check my o2 sensor, vacuum leaks, and electrical plugs that might be unplugged. everything is where it's supposed to be.
what is wrong?
what is wrong?
