Ok guys so I have a 90 supra turbo 5 speed. It has ARP head studs HKS head gasket CT26 57Trim turbo. Greddy front mount with 3" hard piping. 3" exhaust, custom turbo elbow, Lexas AFM with intake, still running stock injectors and pump. After I opened up the turbo elbow it spools way faster but runs way leaner. I am running 12PSI right now and AFR's get up in the 14s when the revs get high. EGT's clime like crazy and would easily pass 2000 degrees if i dont lift. I am not driving it till i get the AFR's under control. I understand i need injectors. I just am wondering what you suggest. Right now i am just trying to run 14PSI. The car is an autocross car so can i run 550cc for now and do i need a fuel pump and regulator. Or what injectors can i run with the stock ecu? Thanks for all your help everyone.
