Car pissing me off...running way too rich.
empera
Authorized Vendor
Philly.
ok so we just installed the walbro fuel pump (and clutch). Car didnt want to idle at first and then we lowered the fuel pressure to 15-20psi, idles at ~11.- a/r.
its about the best i can get it to. Heres the wierd part, if i turn on the headlights the a/r's go a bit leaner. Also if i give it some gas it chugs and seems like its drowning or if i give it more gas it'll go lean. I'm getting sick of this car. Anyone have any clue what could be going on here?
robbo185
693
Chicago
mine did the same.
Is your J-tube still there?
Also that psi is wayyy to low. I bumped mine to 25psi and took out 35% with the maft at idle and 25% with the safc across the map....i idle around low 14 now
empera
Authorized Vendor
Philly.
Mods are:
VPC, safc2, afpr, walbro, 550's, aem wb, etc...etc...
car was running way rich at idle...i even took out 50% fuel and still nothing until i lowered fuel pressure that much.
Also car started to kinda boggle at idle, rpms going up and down, until i leaned it out a bit, taking fuel out.
suprashy
126
Nassau County, NY
Hmmm. can only throw a few recommendations at ya:
1. (are your S-AFC settings correct). # of cylinders, Karman setting, etc?
1a. Go to your setting menu on your TSRM, and make sure u see .5 volts in the TPS section with ign. on and gas pedal untouched.
2. Have you ckd. timing per TSRM?
3. Did u perform the 12v mod?
4. Any codes?
5. Are you VPC knobs pointing at 12 o clock? (u can tweak later if necessary - I didn't have to).
I hope some of the above statements help in solving your issue. Please keep us posted. Thanks and good luck!
suprashy
126
Nassau County, NY
Sorry, I meant go to your setting menu on your S-AFC.
