Car is weak after 4k..
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Well I got my car back together a few days ago and have been driving it. I noticed it is weak shit after 4k rpm. The only thing I added was 440 turbo injecters for the turbo swap I will be doing really soon. Maybe it's the injecters huh? what do you guys think?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Tanya said:
leaking gas from where? got a bad injector o ring somewhere??
I changed out all the rings and even the insilaters for the bottom = / but it is leaking in aournf the maifold / block/ injecters where it all meets. I'll look more into it tomorrow :icon_conf
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
your VTEC is broken, fix it...
that or your ACIS maybe stuck?
damned if i know, but leaky injectors suck, mine literally gushed gas one time at work, had to limp it home with my dad following just incase...
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
= / I put the NA injectors back in. Started her up and saw fuel pouring down. Good thing it is only from one injecter that needs work. I guess I'll change the o-ring on that one again.
SupraDupra500
195
Terre Haute, Indiana
go to your local advance auto parts (im biast cause i work there) and get a fuel injector o-ring kit. any AAP store worth a shit WILL have those o-rings in stock. and make sure to lube them with wd40 or just some spit will do fine. get that afc and tune it, or put your stockers back in.
