Car is completely dead, no lights at all or crank randomly
pattywaggon
10
Bucks PA
I just got done driving my car around the block, has been running fine ever since i bought it about a month ago,
The car randomly just went blank when i turned it off and took the key out,
it doesnt know the door is open, or key n ignition, no horn
its as if my battery isnt there,
I need help asap, i need to get to work tomorrow
I have a 1990 7mgte manual, close to stock
Im running the car on the factory ecu, i was running the maft pro off and on for a day or so tuning it and such but i keep the factory ecu for driving.
I have had a problem once with the cars ecu, it just didnt recognize i had an ecu
But now there isnt any lights or signal for power
Faulty grounds????
the car was running and no completely dead when i go to get back in and start it.
Thanks,
Patrick
Any input is appreciated
Battery is bad or alt is bad and killed it or the terminals are loose. Check them or get it tested.
7m ecus don't go bad either.
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
btw i like how your current activity is Viewing T61 Bolt on Turbo by Cx Racing @ 09:46 PM hhaaha yet you need to get your car started to get to work tomorrow haha just saying :p
---------- Post added at 09:52 PM ---------- Previous post was at 09:49 PM ----------
also check the cable on the alternator, that got loose on me and i basically drained my battery till I got home. I had warning lights on my dash though so i knew something was wrong
pattywaggon
10
Bucks PA
the fuses are fine, just looked at them with a flashlight
there are aboslutely no lights, or relays or anyting going off
im going to check the battery with a multi meter
I only drove for like 5 mins and had the car idle for a minute and then parked it
no i get in and there isnt signal of any time of power going anywhere
pattywaggon
10
Bucks PA
no fuses are getting power
i grounded the battery using jumper cable to the flock and frame just to see if the battery has a faulty ground
any sugggestions
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
AJ'S 88NA;1686357 said:
Sounds like your battery connections and grounds need attention.
Really does sound like its this. I had the same issue and it turned out to be the battery clamps themselves were no good even though they seemed tight.
pattywaggon
10
Bucks PA
fixed it this mourning
i followed the positive wire off the batter under the fuse box.
its blue with a black cover or shrink wrap ect
and turned into 2 white wires that feed into the alternator fuse
it was dry rotted and freyed apart
i litterally just grabbed it and gave it a little tug and it came completely out
krimbed a new and thicker wire with a new lug to the batttery terminal and its been running good
Thanks
