i finally got the car running again yesterday and it was great until... late last night... coming home from the mall and the car popped and then shut off. started it right up but drove it home on limp mode. checked codes and 22-24 and 34 were all present. i hit fuel cut earlier so the 24 and 34 were gone after the efi fuse was pulled and replaced. i just replaced the temp sensor for code 22; i played with it and cleaned the connector and it went away... but code 31 has now appeared and won't go away.
i checked for the 5v signal and it's there. i also clean the connector and swapped out the afm for another good working one and the code is still there.
what else can i do. the car idles fine but when i gas it, the car stumbles and stalls. Help! i figure it out...:cry: :cry:
