Cant Install Driveshaft? Wtf?
YouGotSpooled
290
Saskatoon, Sk. Canada
Okay.. So I did a GE to GTE swap.. blah blah. Anyways, I got a r154 driveshaft but there's a problem..
When I go and slide the slip yoke onto the output shaft on the transmission, it will slide on approx 2inches and stop going in any farther. If I try to ram it in, it seems to hit somthing "solid" and kinda gets wedged in there.. But it isnt metal on metal.
Any ideas what could be causing this? I can stick a flat head screwdriver in there atleast 4 inches, but if i turn the screwdriver head sideways and try to put it in it keeps hitting something like the bushing?
This is a real pain in the ass, I need my car and toyota wants like $500 for a new exstension housing.. and ideas what I can do.. or if there's some crazy trick to installing it..? Or is it sledgehammer time?
Thanks
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
If the drive shaft is from a na supra it will not fit :3d_frown: ,You need one from a turbo supra.:icon_razz
Thanks
crazysupra2JZ
740
Georgia
*edit, besides mk3brent*
^don't know what those replies were all about. since you had a GE motor, you have the w58 tranny. you bought a driveshaft made for the r154. why did you replace the driveshaft?
YouGotSpooled
290
Sorry, I dropped in a 7mgte along with a r154 tranny. Id rather not blow up my w58. :icon_bigg
The r154 driveshaft wouldnt slide onto the w58 output shaft at all because of the spline difference correct?
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
I don't remember how far my DS stuck into the tranny the last time I pulled it out...
But how far off is the rear 4 bolts from the differential?
(also, what are the spline counts for the automatic DS and length?)
YouGotSpooled
290
Not sure about the diff holes.. but the front shaft on the auto DS i had 23 splines and was only 10 1/2 inches long and the r154 shaft was 12" long. This is just the front shaft frome behind the u-joint to the flange by the carrier bearing. There is almost a 1 inch gap between the two cup like things.. I know it isnt in far enough.
Frome the carrier bearing to where it mounts up it is about an inch to an inch and a half away from it.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
could always have a driveshaft shop make you one that does fit hehe shouldnt cost too much unless they want to make a ton of money off ya.....
