I am running a W58 behind my 7mgte and recently replaced the spec stage 3+ non turbo clutch in it because I had a problem with it not fully disengaging sometimes. When I pulled it out, I found that some of the springs were working their way out of the center hub, but couldn't see where they had contacted the flywheel or flywheel bolts, but replaced the clutch anyways. I replaced it with a Spec stage 2+ clutch, resurfaced the flywheel, replaced the slave cylinder with OEM, bled the system, replaced the throwout bearing, checked the pilot etc.
All was good for about a month, then the new clutch started acting up similarly but not the same as the old one. The new clutch tends to engage itself while I am in gear. Here is the typical scenario...
Come to a stop put car in first, no effort required. While I wait in gear, I hear a clunk and my idle drops, and now the clutch is partially engaged, and I cannot get the transmission out of gear. Sometimes it is bad enough to move my car forward if I let go of the brake. There are 3 ways to get the clutch to disengage, 1 rev the engine to about 4k rpm, 2 yank the shifter out of gear, 3 release the clutch enough to get it to start to fully engage and then release it again. With all 3 of these, the clutch will fully release and the trans will go back in and out of gear fine. For instance, if I am stuck in 1st gear, I can yank it out of gear, then as soon as I do that it will go back into 1st without a problem, foot hasn't moved on the clutch pedal.
Not sure what to look at at this point, what could cause this? I cant think of anything transmission related that would cause this, but its such an odd issue. It happens about 40% of the time I have the car in gear at a stop.
