Hi i have an 87 Turbo. im taking the engine out to build it up, so i got everything off that was in the way, the two engine mounts out and the eight trans bolts out. i have it suspended by the cherry picker and trying to wiggle it loose but it wont slide out. i talked to someone and they said that the spline could be rusted and the clutch plate is stuck on the rust. im using sockets to put in between the block and the trans and wiggle it to space it out more but it doesnt want to budge. has anyone had this problem? Thanks:1zhelp:
