Can you start it?
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
Is it possible to start the car with no transmission?
Im on the verge of getting my 7MGE back into the car but I really dont feel like dealing with the transmission today.
Edit: manual transmission BTW.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
The starter bolts run through the transmision so I do not see how unless I am missing something.
Like: Why you would want to?
Bishop92t
773
USA
www.ma70.com
With a 91-92 starter and some shims you could, but I wouldn't recommend putting that kind of force on the cover. Or take the bellhousing off the tranny and mock the starter up long enough to start the car.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Good info Bishop, I did not know they varied in years. I would also worry that with no tranny mount installed you should make sure the fan is going to clear the shroud.
Bishop92t
773
USA
www.ma70.com
Yeah 91-92 got a threaded starter (its also approximately 25% lighter and smaller) instead of the old nut/bolt combo, the bolts thread directly into the starter.
8,899
Yep. And much easier to install with out a lift in my opinion.
shaeff
Kurt is FTMFW x2!!!!
11
Around
yellow: it's MUCH easier (in my opinion) to put the motor/tranny in together. (with them bolted together) i've always done it that way. it's super easy, and then you don't have to struggle with those upper bellhousing bolts.
-shaeff
