Can this wastegate run at 12psi without boost creep?
nissota
70
Jamaica
I am planning on running a Holset Turbo on my Supra. I have removed the stock 18psi actuator and I am contemplating converting a Mitsubishi 10psi actuator.
My concern is the size of the wastegate, the hole is .75" and the flapper is 1.125". Will I get boost creep at 12psi?
If yes and I were to port the hole larger to 1", will I still have boost creep issues?
MKIIINA
Destroyer of Turbos
Plano, TX
im not sure if you will have creep issues but there is no reason why you cant port the hole out some more and this will help if you do have boost creep.
