The TSRM shows the seal being removed when the shaft is out. I'm attempting to replace the seal while the pump is still mounted. I removed the pulley, shaft key and snap ring but I can't get the seal out. I made a real mess trying to get around it with different picks and small screw drivers.
Can the seal be removed from this point or do I have to remove the pump and disassemble the entire thing?
