Can the one NA knock sensor be spliced into the 2 wires of the turbo harness?
mk1spyder
111
Western NC
Title pretty much says it, I came across a brand new NA block and used it for my latest build because I didnt want oil squirters anyways. Well as you all know NA's only have one knock sensor but it should do the trick, of course the block has the bosses for the turbo placement and I could just drill and tap them but i'd rather not as I feel one will be sufficient. Has anyone tried splicing the one sensor into the 2 wire feeds the turbo harnesses use? I dont see any problem with it except that possibly the one peiziocrystal sensor might not generate enough voltage/amperage to be split twice and Ill get a reduced signal.
mk1spyder
111
Western NC
nebdoy else? now that I think about it plenty of people splice safc2's into their knock sensor wires to monitor knock and it does fine so I guess itll be ok.
