supra90turbo said:Not really ouch.
The only time the valve is closed is when the AC is on.
It's usually open and circulating hot water through the core.
rumptis said:sorry but you are wrong.
It should always be closed unless you have the heat on, otherwise in the middle of summer you would always be heating your car unless you have the AC on.
You can get rid of it if you wish but you will not be happy with the results when it gets hot out.
midniterider said:Two pages on this simple subject?? man
