Can i use a gs300 crosmember into a mk3 or has anyone done it already ??
nightrider760
219
escondido , tijuana
I will be getting a 2jzge off of a gs300 for my swap ,but since Iam in a tight budget i could get the motor,wiring harness,ecu,crosmember,motormounts, for less than 600 bucks. Instead of spending more money purchasing the sump,wich it could be spend somewhere else . I do understean that some fabrication involved but has anyone done it??
Never seen it done, and more than likely nothing will line up or be in the right place. You'd spend more trying to get that to work than buying the correct sump...
Flateric
946
Calgary, Alberta, Canada
Dude, you are going to have to get a rear sump oil pan, seriously. Way less work and cost than doing the crossmember. Think of the steering rack and suspensions. I know you wanna save some cash as we discussed but you can't skip the basic things that are going to make the motor fit in there properly in the first place man. Give me a ring tomorow.
