I have a 2000 Nissan Altima that I can't figure out. I was driving this car with no problems, and had to slam on brakes. At that time, the car went dead, and has never started again. When I turn the key, it sounds like a small electric motor is running, but doesn't even sound like a motor turning over. Here is a list of some of the things I have done, and been told.
The car does NOT have a fuel cut-off!
I first thought it was timing chain. I was told that it has 2 chains. A mechanic advised me to pull the valve cover and see if I see it. If it was in place, then start at the starter. I found the upper chain in place, and after replacing the valve cover noted that it does turn when the key is turned. The motor has a chain from the crank to an intermediate sprocket, which turns the upper chain. Seeing the top chain turn (through oil spout), tells me that both chains are good, because the lower turns the top.
I removed the starter, and took it to a starter repair shop. He tested it, and said it has plenty of life left in it.
I have replaced the battery for S&G's with my Optima Red Top at 13.5 Volts
It loses about a half of a volt between the battery and the starter, so the cable is good.
The crank is turning, as all of the belts turn when cranking.
Compression is somewhat a new thing for me to totally understand. I have a compression tester that was bought recently to test my car. I set out today to do a compression test on this car. The first two plugs I pulled had so much oil in the plug hole that it covered the entire spark plug socket. Could that be from not re-installing the valve cover right?
I did a compression test on one cylinder (other plug was put back in) , and got a bit confused. That cylinder showed a big fat 0. With the C/R's that I have seen on here, a BHG cylinder still shows 70-100 in the bad cylinder. What does "0" mean? There is no sound of any rod or piston trouble. It just sounds like there is no compression.
I also noticed today as I went to check the compression, that with the key in the on position, there is some sort of buzzing in the engine compartment. I started looking for the source, but could not locate it. Could it be some sort of coil or igniter problem? Does that car even have those? It was coming from somewhere near the air filter, but didn't seem to be coming from the distributor.
I'm almost ready to start a part out of this car. If I can fix it, it will keep me from having to find my son something to drive for a little while.
Thanks for reading this far! And, Thanks for any help you can be.
