And how will this affect the performance of the turbo engine? Cheers, Roy
tte Breaking In - in progress Mar 30, 2005 940 0 0 Northern California Nov 19, 2005 #1 And how will this affect the performance of the turbo engine? Cheers, Roy
shaeff Kurt is FTMFW x2!!!! Staff member Super Moderator Mar 30, 2005 10,592 11 38 Around Nov 19, 2005 #2 not by a whole lot. the intake cam is a little different, and will start choking the motor at around 350-400hp, due to less lift, but more duration. if you stick a turbo intake cam in there, it'll be fine, as the heads are the same. -shaeff
macsupra76 New Member May 17, 2005 128 0 0 45 Calgary AB Nov 19, 2005 #3 NA head will fit Turbo block, NA cams are good for low end on turbo block.
forcefedsupra aka, Turd Furguson Jul 19, 2005 463 0 0 Jacksonville, FL Nov 20, 2005 #4 I have an N/A head on my turbo. With turbo cams, the head is exactly the same.
