can a compression test be done w/ the engine out of the car?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i need to do a compression test on my 1j b4 i start buying all my parts but my engine is out of the car and its just sitting on a pallet. could i just hook up the compression tester and turn the crank until it compresses or is there another way to do it? what are some good compression numbers so i know if my 1jz is still good?
souprat
fairfax VA
it wouldnt work with you just turning the crank by hand, unless your such a badass that you can spin it up to 250rpm. you have to get the starter to turn it over.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Maybe you can get an impact gun and put it on the crank bolt and have at it? I don't know if you can get the RPM's up high enough though. Worth a try.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
mount the starter, jump the cables for the starer, make sure tehre's some oil in there.. and thats how i've done them in the pass.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
yea i know but its gonna take like a month cuz i ordered a jun flywheel so thats why i wanna know if i can do it w/ out the flywheel
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Hell, you can probably see if anyone has the automatic flexplate that they aren't using and bolt that on. I have one at my home. But, I'm currently deployed. See if you can find one.
Dirgle
Conjurer of Boost
Pauma Valley, CA
Nucleon said:
For a proper compression check, the engine must be at operation temperature! The numbers from a cold engine are often useless.
I was wondering if somebody was going to mention this.
