Can a 2jz oil line kit be used for a 1jz?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i'm in need of a oil line kit for the 1jz but i can't find one so i was wonderin if the 2jz kit is the same as the 1jz kit where i can just bolt it up?
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
Buy the flanges and make the oil lines yourself, you'll save $100.
Every manifold is different, and the chances of buying a premade kit that will properly fit you're manifold is highly unlikely.
I ordered a boost logic oil line kit for my car ($200), when i got it, it was just summit branded oil lines, not even Earls..., so i returned it, bought flanges locally for $35, and called summit for the same lines for 1/3rd the price.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i was thinking that might be cheaper, where can i get the flanges, the lines and the fittings from? i kinda live in the boones so i might have to order the stuff on the net
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
For fanges PM ARZ, or MDCmotorsports
I run a billet aluminum ARZ -10AN flange for the upper oil pan, and a MDCmotorsports T4 -10AN flange. Both have worked out great.
Ric
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
if you have to use an oil line feed adapter for your turbo (meaning, a bolt on flange not a screw in deal), do not use the o-ring ones. It will leak. Use a good quality gasket.
