Camshaft regrinds
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
Over the winter this year the 7m is getting some more mods. The head is already ported and will get a little more. Im not really into spending big money on OS valves and BC cams since I will also be painting the car and installing an AEM EMS.
Ive seen the SIP regrinds which seem to be pretty affordable and good for street use. Will these cams turn power up to 7-7.5k with upgraded valve springs? Im looking for options to get the most power out of the 60 trim CT26 I had built last year. I would imagine adjustable car gears should be on the list too..?
suprarich
Guest
Nov 9, 2005
2,187
ohio
I am doing them as a 274 duration .310 lift. You don't have to have adj, cam gears, but to get the most of the cams you should have them. I grind the cams on the oem center lines, so you can install them just by lining up the hash marks on the oem gears and the notches in the rear cam gear plate.
