cams and overlap
hks_trinidad
nyc
hey guys im looking at getting some aftermarket cams i read that you will have overlap with aftermarket cams .how bad is this ? im looking for a cam with a good powerband what duration and lift do you think i should get thanks
89supturbo
186
Delmar, NY
u get overlap with all cams aftermarket cams are just worse, as far as aftermarket 7M cams u can wait a month or two for the brian crowers ro come out and i think HKS makes a really expensive set. the BC's are going to be 264 and 272 duration, for a fat powerband the 264's would be best but the 272's yeild a bit more top end power
SupraDread
153
New York
Hey Trini I think I PM'd u a while back about a Supra tech in Brooklyn. He is another invalueble source for your MKIII. You might have even heard of him.
SupraDread
153
New York
There are better ways of increasing power in your 7M without touching the cams. They are pretty well suited for differnt mods well into 300 HP. I would spend the money elsewhere in mods b 4 seeking new cams.:naughty:
SupraDread
153
New York
Suprapowaz!(2) said:
Isn't one of the vendors having a group buy on the Brian Crower Cams?? What happend to the vendors section on this forum? Did they get the boot?
No they did not get the boot. U just have to click on to vendor as they are no longer listed on the home page, but they are still there.:icon_bigg
suprarich
Guest
Nov 9, 2005
2,187
ohio
Over lap is just the number of degrees of rotation that both intake and exhaust valves are open. Big overlap numbers are usually found in NA motors.
Lots of over lap on a turbo motor will cause more low end turbo lag.
There is no rule that aftermarket cams have more overlap, this is just how most aftermarket cams are ground, being that most are made for NA motors. most aftermarket turbo cams don't have as much overlap as their NA counterparts as they are ground on diffrent centerlines than NA cams.
Some 257-264 duration 8 to 8.5 mm lift cams would be some nice steet/strip cams.
hks_trinidad
nyc
yo dread wasup . i havent heard about the supra guy in brooklyn what is his name ? maybe one of my other friends heard of him , anyway if you want to see a race tonight come out to the nassau a 2jz powered mk3 will be racing a evo most likely
RacerXJ220
Interdimensional
Abalama
On a turbo motor, lift is what I'd pay more attention to when buying cams. I forget what you can actually fit in the 7M head before you have do machine work...
figgie
Twin Cities, Minnesot-ah
8.9mm if i recall correctly.. after that requires machine work to grind into the valve bucket seat.
SupraDread
153
New York
Yo sorry I haven't been on line lately with the holidays and all. Two things about that race. One I relocated to Michigan. Two if the MKIII is a red one then it belongs to the tech I was telling u about in Brooklyn and his name is Boy. The EVO belongs to Ricky more than likely 'cause those two are always going at it and without being there I know Boy won that race.:icon_bigg
