I just had an alignment done tonight and the guys said that my camber is off a tad. I looked at the printout with the specs and the left front wheel's camber is -1.3 and spec is within -0.6 and 0.4. Also the left rear is just barely in spec at -0.8(spec being -0.8 to 0.3) I the last time I had an alignment done at the same place last year and they were able to bring it in spec. Is there a part that might be broken that would help out with this? Or did the guy that did it this time just not work hard enough?
