I did my head gasket and the injector wiring was wrong so I corrected it (see previous thread) and now my car does'nt want to start. it was idling about 500 with the improper injector wiring. Can the bottom end be 180 degrees out of sync with the cams or is it as long as the crank it at TDC and the cams are alinged it's all good?
I have everything @! TDC now and the cas looks like it's alittle off.
Any help is greatly appreciated
