Hi all, after some help. Im really stuck so turning to you guys to hopefully help me.
Right i bought a supra (89 7mgte r154) early this year. I was told by the seller that the bottom end was knocking between 1500 and 2500 rpm. Ok no problem ill re build it. Went to see it. No knock what so ever, engine was quiet. However had no power at all, turbo was glowing with throttle. Odd. Would only rev to 5600rpm. got it home and began work. Had a dead tps, changed it no better. Turned out the exhaust cam had skipped TWO teeth RETARDED. So i advanced the cam two teeth, and timing is now all correct. So started her up, revs perfectly now. However the knock has reappeared. Well its not a proper knock its more of a rumble as such. Ive thought and thought about this. What the hell has happened. Exhaust cam retarded two hole teeth no knock, correct timing knocks?
Heres a video of it. Excuse the state she is in and flames. I was so chuffed it was actually reving properly. Shes undering going a total revamp.
http://www.youtube.com/watch?v=YgBpgJKUz6Q
My mate thinks its the tensioner that is causing this sound. You can here when its revved the rumble. Any help will really be apreciated as im really new to these cars. (on my other videos my charged clio know you yanks love superchargers haha
