cam shaft sensor
sweetLou
katy tx.
when i got my 87 supra turbo someone had cut out the connector from the wiring harness going to the cam shaft sensor and they just wired it together i was wondering if someone could tell me what wires colors match up with the connector in place so i can check to see if its right
Halsupramk3
444
Mississippi
here is how the cps should be wired. this is an early loom so i dont know if the colors are the same on your car. i believe one will be +5v. one is ground. one is g1 sensor and the other is g2 (the magnetic ear things in the cps).
