Cam Sensor Wiring
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
I was checking over my wiring before installing my 1JZ into the car and noticed that my front cam sensor wires going into the plug are starting to fail. The wires are still connected but the insulation has broken right at the plug. I was wondering if there is a way to take apart the connector so I can rewire this?
10secdream
Got Boost?
Sep 11, 2007
767
Well i guess I spoke to soon the wires did infact break. I was thinking of just solding some wires directly to the cam sensors and then use some connectors I have back from the RC days so I can disconnect it if need be. Any objections?
fandffan
149
Bowling Green, OH
Wiring is wiring as long as it is done properly. Just make sure the connections are separate when soldered. And heat shrink is the best thing to use. As long as there is a good connection you should have no problems.
