cam postion need to knw where marks are
7mgtesupra
28
tampa,florida
trying to get my car on time got the timeing belt on the right teeth and lined up put iam trying to get the cam on time cant find the marks like which way do i turn it .cause my 7mgte turbo it does not have any get up and go.its an automatic is that why.it should at least spen tires right.:1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp:
tsuper92
supra addict
Apr 7, 2005
1,376
mass
the steel cam gear has a hole in it that line's up with a notch in the aluminum housing.then you just need to slide it in centering the bolt in it's addjustment.hope that make's sense.it's easier to do then explain
my auto would only leave rubber exiting a corner
ginglesturbo
Boost Nazi
Dec 1, 2007
129
Charlotte N.C.
you need to make sure the marks on the top of cam gear are striaght up and make sure the motor is at top dead center then check your tenson on your belt
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
1. set crank to TDC
2. set cams to straight up
3. install and tighten belt
4. line up these marks (2nd image)
5. put cps in
6. set timing
Merry Christmas
