Cam Position Sensor CPS Removal/Installation Procedures?
jons87mk3
17
HI
I'm currently trying to replace my valve stem seals and have to remove the Cam Position Sensor to do so. I can't find any info in my manual or in previous posts to explain how this is done. If I remove it, does it have to be re-clocked some how? The motor will be at TDC and I believe there is a mark on the body for the rotor portion, but how do I make sure the body is in the proper position? Thanks for the help!
jons87mk3
17
HI
More worried about installation.... Just read something about timing it like a normal car with a distributor. Is that all I have to do? With my Buick T-type, had to adjust it by reading voltage.
