umm
If you line up the marks on the camshaft gears with the timing marks on the top of the timing case as 1j stated.
Then you need to place the crankshaft pulley at 0 TDC.
Just placeing the pully at 0 does not v erify that you are at TDC.
If you look at the TSRM there are directions to verify that you are at TDC.
