Cam Angel Sensor! Timing
FlikRacing
93
Michigan
After a long search I cannot find much. or if i do find something it's dumb and not worth trying. I just got done with my motor is all back together rebuilt, Now How do I time the damn Sensor, I have it at TDC right now, is that where I start?:naughty::naughty::naughty::naughty:
FlikRacing
93
Michigan
Im good I set up the Cas so I can only advance it. I don't want to retard the timing, Right now it's on spec: if you go up it advances it thanks. I figured it out.
:icon_razz
jdub
Feb 10, 2006
10,730
Valley of the Sun
It should look like this:
Make sure the crank is pointing at "zero" and both cam gears are aligned to the index mark on the back plate.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
It helps if you SPELL your searches correctly.
Same applies to your thread titles.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Ummm...I'm not sure what you mean by "cannot retard timing". It really needs to look like the pic I posted...that puts the tightening bolt at about mid point in the CPS securing slot. You are going to need +/- to get your base ignition timing correct.
Mk3runner
2,033
Nor Cal
meaning he is like a tooth or so off from having the cps completely center which would allow you to move it either way instead of one way.
which I might add means try again till you got the thing perfect and able to adj both ways.
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
fixed :)
