hello all, :1zhelp:
few of you know me personally and from the forums (sm/sf) but i need some help from you guys.
im getting ready to do a small na-t build for my girlfriends 89 supra which has blown the hg, with my car i did the whole swap itself na-to-turbo everything so im trying to learn the na-t builds, and yes im reading the faq sections and printing everything to go back to if needed.
here is what im doing for her, no more than 350rwhp, she currently has (parts to be used) titan 1.4mm mhg, arp head bolts, 3" ddp, 54trim ct26, ngk gte iridium plugs.
my questions are......
-how much boost will the stock afm hold before it hits fuel cut?
-will the distributer be a problem with spark? with upgrade wires.
-how much hp will that stock tranny hold?
-will it be a problem running the stock 9.2:1 compression at 10psi on pump (93 octane)
-will the 1.4mm mhg be ok or should i up it to the 2mm to lower the compression some?
i think thats it for now, thank you for anyone willing to help and that can answer my questions and any extra info that can be provided would be awsome.
thanks
-sean :icon_bigg
thanks
-sean :icon_bigg
