Alright, so I bit the bullet and bought it. I've only noticed a few small things here and there. All the hosing is going to be replaced, the turbo shaft felt good, no rubbing on the housing or touching. The oil looks good, still going to change it. The mechanic gave me a new fuel pump, he gave me a 5k mile warranty. Hes a good old boy. Really nice man. I got the fuel pump in, the old one was badly corroded. The car started right up. I've found two issues that I'm not sure about, apart from it needing tires, brakes, shocks. Issue #1: there is a high pitched, almost electrical whine coming from the fuel pump, or near that area. Are there any ground points that could be causing this? I'm going to test all over to see if there is a ground loop going through some where. Issue#2: When the car is at low rpm, if you give it gas it hesitates. Like a blurg blurg blurg sound lol, but only for a second, then at higher rpm its fine. I'm thinking its just needing new plugs and wires, and I'm assuming a bad mass air flow sensor could cause it, since these have been in it for 3 years with no running.
I'm trying to run through my head any questions that may come up that are one off questions. There is a wealth of knowledge on this forum, I love it. Thanks for the help guys.
