I just built my motor and have about 500 miles on it, but it burns some oil. I don't see any evidence of oil burning on the plugs and I assume it's not valve seals since it is a remanufactured head. No smoke on startup either. The turbo felt a little excessive on free play when I had the motor out, so my question is, is the oil coming from the turbo. The only time I can actually see the puff of smoke is coming to a stop, pushing the clutch in, and letting off the gas. Just as the rpms come down some smoke comes out. It is blue smoke. Is this caused by turbo seals going bad? I do get a little bit of smoke on acceleration, but it isn't easy to see unless you are on a dyno. What do you guys think?
Thanks,
Ian
Thanks,
Ian
