Hello,
i want to use the BC stage 2 cams on my 7M, at the moment i use the NA Cams and rev up to 7000 rpm.
if anyone use this cams:
how is the Idle?
how high can i rev?
should i change the cam timing ( adjustable camgears)?
is it better tu use the Stage 3 Cams?
i life in germany there is it very problematic to use this streetlegal, so it is importet that the idle is not to rough, and it is not possible to rev higher then 900 to 1000 rpm at idle....
regards stefan
how is the Idle?
how high can i rev?
regards stefan
