Hoping for some insight and some help with this issue. I'll give as good of a rundown on the parts as I can up front and see if there is anything that might help someone help me. After 8 hours today, I"m stuck.
This is a brand new from Toyota 7M block, refreshed/rebuilt head, etc. EVERYTHING on this motor is brand new or less than 100 miles on it. The car will start up just fine, runs for 3-5 seconds, and immediately dies. It barely recognizes me giving it gas and I can sometimes keep it running for a little longer.
- Fuel pressure is good
- No codes
- No vaccuum leaks to be found
- AFM tested good
- Brand new 93 octane in the tank
- I think I have all grounds in place, but would be glad to check for anyone who can tell me where they all should be. I have one behind the a/c compressor, wire bundle ground under the intake, ground strap from firewall on passenger side to head, one from body to the bellhousing of the transmission, and one at the transmission mount.
Again this is a new 7M with new Lipp turbo, 550's, Lex, AFPR, Walbro, new wiring harness, new plug wires, new plugs, no leaks or problems of any kind that i can find. Again no codes and it appears everything is working as it should, but obviously it isn't because it only runs for 3-5 seconds.
Any ideas? Thanks in advance for any help
- No codes
- AFM tested good
