brakes
IETV8S
1.5JZ WOOT WOOT!
Mar 24, 2007
60
calgary
hey i was just wondering how hard of a job it is to do both the front and rear brake rotors, is it just the same remove caliper slide of rotors, or is there more to it?:1zhelp:
remove caliper, remove caliper bracket, remove rotor. install in reverse. dont let the caliper hang by the brake hose or it might crack/break and then you will have to replace that too. when doing the rear make sure to match the hole on the rotor up with the bigger slot so you can adjust you e brake.
if your really not up to the task take it to someone who knows what they are doing as its your brakes.
dumbo
1,913
Albera, Too Far North
Speed doesn't kill, it's the stopping that does. So listen to his last comment but don't worry it isn't to difficult. Consult your local TSRM for help.
TomFraser
I'm doing them right now, with calipers, I recomend at least greasing the caliper slides as mine where removed from the torque plate only with the help of a 20 pound sledge hammer and a good vice. So...
BUY PB BLASTER, every slide was frozen for me
Have a STRONG 12mm Hex bolt, to remove rotors I was impacting a 12mm bolt into the rotor that will push it out, and the bolt snapped, don't skimp on the bolt
the job is pretty simple, 2 bolts holding on each caliper and it comes right off.
^its better to get 2 bolts and evenly screw them in or you can also just spray pb in the center hole and around the studs and hammer them off.
mirage83
457
Georgia
And don't panic when you see how thin your parking brake (e-brake) pads are. They're thin even when brand new, and expensive to replace.
iwannadie
981
gilbert, az
That's what I did, 2 bolts and slowly work them alternating to push the rotor off.
and you snaped the bolt. what size impact 1/2in? i use my makita 14v 3/8 impact for those and usually the the threads will strip first.
toyzforme
I need deeper pockets
Jan 1, 2008
103
Summerville, SC
Only place I found the parking brake pads was at horsepowerfreaks.com
and they want $100 for a complete set. Ouch the front and rears don't cost that much unless you are putting performance pads on
They're just reselling the OEM pads, cut the middleman and go to the dealer.
Yes, they are expensive as hell, and it's why I tell people that want to drift these cars to not use the e-brake...
92nsx
2,957
Clearwater, MN
Poodles;1478781 said:
Impact gun = break shit ;)
BUZZ!! Impact gun = work gets done faster.
...........Brake shit = inexperienced operator.
<----has never yet broke anything because I used a impact.
1/2 impact for a 12mm bolt head is too big. 3/8 impact or air ratchet would be the right size to use.
TomFraser
size does not matter... I can turn the gun down so that I can hold the end from turning, I have to show a picture of the bolt I used that got stuck, if it was actually metal I would have been fine, I just grabbed the first 12mm hex bolt with the proper thread in my misc. bucket of bolts
Also, Air ratchet would not have had the power, and I don't have a 3/8 gun...
