ok....
My brakes drag occasionally.....to the point where on the interstate, my car will be running 0 vaccume up to 2 psi just to maintain a speed of 70mph. It makes my car run hot. they will do this sometimes after I hit the brakes, and then after a while, it will just go away. I have to get this fixed, as my rotors are turning blue.....lol Its only the front two sticking, as the rear wheels are not getting warm like the fronts are.
Here is what I have replaced.
Stock lines are now SS braided goodridge lines
Front Calipers are rebuilt about 3k miles ago.
New master cylinder.
All brake hard lines detached and blown out with 90 psi of compressed air.
New pads on all four corners
New dot 4 fluid in everything.
What is the deal? There shouldn't be anything left to cause a problem!!!!
