brake system problem
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
Hey guys.....When I suddenly apply my brakes, the whole car jerks to the left. I have two new calipers, I have bled the lines numeros times (with a friend), although when I bleed the passenger front one the fluid comes out at a much weaker stream than all the others. I do have brand new stainless brake lines as well and a new master cylinder. My buddy and I checked the codes on the ABS unit just like it tells us in the TSRM but I have no codes....There is some kind of valve (faded blue in color on my car, it attaches to the engine bay right by the intake manifold) that the hardlines go to after the master cylinder....could that be the problem? Any ideas?
thanks,
val
zigspeed10
31
ohio
I just had the exact same problem and I had to replace the abs actuator. Your problem will be between the abs actuator and the caliper, don't worry about that blue thing as that wont be your problem. I worked my way from the caliper to the abs actuator by bleeding the line going into the caliper then at the hardline to softline connection and then to the abs actuator and thats where my problem was.
