I have an 89 na don't know if brakes were any different in different trims and years.
Anyways I got some seriously steering wheel shaking 60mph+. Tires/Wheels balanced. The shaking occurs from front right wheel as I can see the hood bouncing on the right side... I've had the wheel moved to the rear. Both rear wheels are a slight bit bent and the front are fine. I notice when I stop the steering wheel moves slowly as well, and the car moves back and forth as well as the wheel pulling to the right a bit when I brake. So I believe I have a badly "Warped Rotor". Anyone concur?
Also more about the brakes. I just randomly tested to see how good they are by slamming hard on the brake at 70. Went about a half second without even slowing down. THen my face came off as it slowed down to 40 and then it stopped slowing down as quickly. Also making a "Vrrrrr" sort of sound, kind of a deep vibration sound, (Assuming warped rotor sound). It's fine for everyday driving but once I get the 7mgte in and all I want to make sure it's set well for good stopping power. Also it's not just low pads we had checked the car about two months ago and the pads were around 70%.
Low on money as I can't swap yet but brakes come first for safety. Any idea on what's going on here? Need to replace fluids? New rotors and all? I'd pay a bit for drilled or slotted rotors for the nice look and longer life and not looking dirty nor rusting.
